All updates that were set available by last july, 14.
(Ben, I cannot list 333 updated packages. I can list kernel 4.16 and nvidia 396.24)
Although nvidia 396.24 has built fine against kernel 4.16 in my laptop, it has not in the desktop (???)
Upon rebooting, besides no graphical support because of nvidia’s failures, desktop also does not connect to internet (by cable) and also does not see USB devices …
This is certainly a rather vague problem report so far, I’m posting it anyway just in case someone else has had such problems and can say something about.
I wonder if some packages are lacking in the new updates, particularly those related to the specific motherboard I have in the desktop (intel DB85FL).
I’ll try installation disk in live mode to download packages like kernel, nvidia, for reinstallation with replacepkgs replacefiles
Downloaded x11-driver-nouveau in live mode with the installation disk. Then, rebooting in recovery mode, I’ve installed x11-driver-nouveau and reconfigured X with XFdrake to use xorg-nouveau. Reboot. Graphical environment OK. Also then cable internet was OK.
1-Why nvidia 396-24-1 worked (downloaded from testing non-free repos) was built in kernel 4.16.13 in my laptop and the nvidia 396.24-1 (downloaded from regular non-free repos) was not built with the same kernel at my desktop?
2-Why, in the recovery mode, cable network connections and usb’s were not working?
# LC_ALL=C urpmi --replacefiles --replacepkgs --force dkms-nvidia-current-396.24-1-omv2015.0.x86_64.rpm x11-driver-video-nvidia-current-396.24-1-omv2015.0.x86_64.rpm nvidia-current-doc-html-396.24-1-omv2015.0.x86_64.rpm
found package(s) nvidia-current-doc-html-396.24-1-omv2015.0.x86_64 in urpmi db, but none are installed
The problem seems to be solved although I don’t know why.
Building nvidia drivers with kernel 4.16 became successful after I removed many old kernels (since 4.13.X). Just would like to know why is this so!
Just noticed that x11-driver-video-nvidia was found in old kernels trees and guessed my urpmi database could have something to do with it … After removing old kernels I’ve installed nvidia packages with no problem.
