Copy an existing installation to another disk with different partition sizes
  • OpenMandriva Lx version: OpenMandriva Lx 3.0 Kernel 4.11.3-desktop-2omv
  • Description of the issue (screenshots if relevant): After moving the system to the new disk, as described below, the boot process doesn’t start (Black screen).
    What did I forgot?
Situation
  • Boot from usb stick (/dev/sdb).
  • Mount the source disk as /dev/sdc.
  • Mount the destination disk as /dev/sdd.
  • Check the partition configuration of the source disk.
    parted /dev/sdc
    GNU Parted 3.2
    Using /dev/sdc
    Welcome to GNU Parted! Type ‘help’ to view a list of commands.
    (parted) unit GB
    (parted) print
    Model: Integral Courier (scsi)
    Disk /dev/sdc: 63.3GB
    Sector size (logical/physical): 512B/512B
    Partition Table: msdos
    Disk Flags:
      Number Start   End     Size    Type     File system     Flags
      1      0.00GB  8.39GB  8.39GB  primary  linux-swap(v1)
      2      8.39GB  61.9GB  53.5GB  primary  ext4
    (parted) quit
  • Create the partition configuration of the destination disk /dev/sdd
    # **parted /dev/sdd**
    GNU Parted 3.2
    Using /dev/sdd
    (parted) print
    Model: USB DISK 2.0 (scsi)
    Disk /dev/sdd: 32.0GB
    Disk Flags:
      1      1049kB  2149MB  2147MB  primary              lvm
    (parted) mklabel msdos
    Warning: The existing disk label on /dev/sdd will be destroyed and all data on this disk will be
    lost. Do you want to continue?
    Yes/No? Yes
    (parted) mkpart
    Partition type? primary/extended? primary
    File system type? [ext2]?
    Start? 1
    End? 8000
    (parted) print
    Disk /dev/sdd: 32028MB
    Disk Flags:
      1      1.05MB 8000MB 7999MB primary ext2        lba
    (parted) mkpart
    Start? 8000
    End? 32000
    (parted) print
    Disk Flags:
      2      8000MB 32000MB 24001MB primary ext2        lba
    (parted) quit
    Information: You may need to update /etc/fstab.
  • Format the new /dev/sdd1 partition as a swap partition using mkswap.
    Format the new /dev/sdd2 partition with the ext4 file system using mkfs.
    # mkswap /dev/sdd1
    mkswap: /dev/sdd1: warning: wiping old LVM2_member signature.
    Setting up swapspace version 1, size = 7.5 GiB (7998533632 bytes)
    no label, UUID=924f3a08-29d8-4799-b130-76660a68c954
    # mkfs.ext4 /dev/sdd2
    mke2fs 1.43.4 (31-Jan-2017)
    Creating filesystem with 5859584 4k blocks and 1466368 inodes
    Filesystem UUID: 6c480049-6b6f-484c-93e0-9e3e2ea7d064
    Superblock backups stored on blocks:
         32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208, 4096000
    Allocating group tables: done
    Writing inode tables: done
    Creating journal (32768 blocks): done
    Writing superblocks and filesystem accounting information: done
  • Verify the results, by printing the partition table of the /dev/sdd disk.
    parted /dev/sdd
    GNU Parted 3.2
    Using /dev/sdd
    (parted) print
    Disk Flags:
      1      1049kB 8000MB 7999MB primary linux-swap(v1)
      2      8000MB 32.0GB 24.0GB primary ext4
    (parted) quit
  • Mount the /dev/sdc2 and /dev/sdd2 disk partitions:
    /dev/sdc2 as /media/5f6bfba0-401a-48f6-a76d-2c160a751d93
    /dev/sdd2 as /media/4cab8a7e-3c7f-43f7-a58c-45870642bc1f
  • Copy the content of /dev/sdc2 to /dev/sdd2
    rsync -avzr /media/5f6bfba0-401a-48f6-a76d-2c160a751d93/ /media/4cab8a7e-3c7f-43f7-a58c-45870642bc1f/
  • Update the bootloader configuration for Grub:
    • The new partition is mounted as: /media/4cab8a7e-3c7f-43f7-a58c-45870642bc1f (See above)
  • Make some in-memory file-systems available under the new root:
      # mount --rbind /dev /media/4cab8a7e-3c7f-43f7-a58c-45870642bc1f/dev
      # mount --bind /proc /media/4cab8a7e-3c7f-43f7-a58c-45870642bc1f/proc
      # mount --bind /sys /media/4cab8a7e-3c7f-43f7-a58c-45870642bc1f/sys
      # mount --bind /run /media/4cab8a7e-3c7f-43f7-a58c-45870642bc1f/run
  • Get a command line inside your system:
      # chroot /media/4cab8a7e-3c7f-43f7-a58c-45870642bc1f
  • Update the grub environment “/usr/sbin/update-grub2”
      # update-grub2`
  • Exit the chroot and unmount all the stuff.
      # exit
  • Update /etc/fstab to reflect the new partition locations. The UUID can be found in the above format step.
      # /etc/fstab: static file system information.
      # Use 'blkid' to print the universally unique identifier for a device; this may
      # be used with UUID= as a more robust way to name devices that works even if
      # disks are added and removed. See fstab(5).
      # <file system>                           <mount point>  <type>  <options>  <dump>  <pass>
    UUID=924f3a08-29d8-4799-b130-76660a68c954 swap           swap    defaults,noatime 0       0
    UUID=6c480049-6b6f-484c-93e0-9e3e2ea7d064 /              ext4    defaults,noatime 0       1
  • Reboot with the newly created disk
After ‘update-grub2’ does ‘grub2-install /dev/sdx’ need to be run?
Edit: ‘update-grub2’ only updates grub2 menu (/boot/grub2/grub.cfg) doesn’t install the boot loader. Probably need to run ‘grub2-install /dev/sdx’. That would be run while you are chrooted in to new system right after you run ‘update-grub2’.
Hello Ben79,
Thanks for the tip, it solved the problem.
    Regards,
    Albert
Excellent news.
@vhelmont please mark Ben’s answer as solution.
Hello mandian,
How do I mark an answer as a solution?
Regards,
Albert
Each post in a thread has a set of small icon near Reply button. Just select the post which solves your issues and click on the button as show in the image below.
All right, everyone, thanks for everything. Time to close this one.
