Control panel
I am a bit confused about control panel at plasma:
First, I have put at control panel links for firefox, MCC, etc and all of them used to vanish if I turn the computer off (??)
Then, I set “block widgets” and the links stayed there after reboot but “notification area” disappeared. Then I tried to put lost “notification area” default icons back with “add widgets” + icon by icon. After a while, I noticed there is a notification area widget itself and when I add it the control panel shows two clocks, two nms, etc.
Finally, I cannot remove duplicated icons. In fact I don’t know how to remove any icon in the control panel!
If someone can tell me how to handle this problems, please tell me!
Thanks
Sorry, I have just learned how to remove icons. Vanishing icons is still a doubt although it has just stopped to happen. This is, of course, a minor problem …
Thanks again.
Well no thanks as no one did really help :wink: How did you solve your problem?
