Can't start LXQt-Desktop
after changing in
OM Control Center -> OPenMandriva repo-picker -> Rock and Release
I have
$ dnf repolist
Letzte Prüfung auf abgelaufene Metadaten: vor 1:13:19 am Sa 31 Aug 2019 13:25:40 CEST.
Paketquellen-ID                                    Paketquellen-Name:                                                    Status
cooker-x86_64                                      OpenMandriva Cooker - x86_64                                          14.971
google-earth-pro                                   google-earth-pro                                                           2
rock-updates-x86_64                                OpenMandriva Rock - x86_64 - Updates                                     476
rock-updates-x86_64-non-free                       OpenMandriva Rock - Non-free - x86_64 - Updates                           12
rock-updates-x86_64-restricted                     OpenMandriva Rock - Restricted - x86_64 - Updates                          0
rock-updates-x86_64-unsupported                    OpenMandriva Rock - Unsupported - x86_64 - Updates                        57
rock-x86_64                                        OpenMandriva Rock - x86_64                                            15.662
rock-x86_64-non-free                               OpenMandriva Rock - Non-free - x86_64                                    155
rock-x86_64-restricted                             OpenMandriva Rock - Restricted - x86_64                                  164
rock-x86_64-unsupported                            OpenMandriva Rock - Unsupported - x86_64                              13.281
with the Repository
and
$ sudo dnf --refresh upgrade
has more than thousand packages updated.
Now I can’t start LXQt-Desktop from sddm-Desktop. Fall back and always land on sddm-Desktop.
How can I repair this?
How can I remove ‘task-lxqt’ and than reinstall again?
with regards
Ch. Hanisch
Fresh install. And quit mixing repositories from different releases. From here:
If you mix different release/update channel repositories and you break your computer the solution is to do a fresh install. And after that fresh install don’t do this again.
Yes. After a new installation I have only
$ dnf repolist
Letzte Prüfung auf abgelaufene Metadaten: vor 14:30:20 am Sa 31 Aug 2019 21:41:02 CEST.
and much problems with missing packages.
with regards
Ch. Hanisch
