ben79
(Ben Bullard)
1
Packages are here-x86_64 and here-i586. Please report any issues in this thread, if the issue is major then please file proper bug report here.
Legacy nVidia packages are “In Progress”, there are some issues to resolve before we can package them.
You all know the rule about testing right? “Test it now or regret it later”.
ben79
(Ben Bullard)
2
I guess the response means these drivers work flawlessly.
I installed it and, following the suggestion, I launched XFdrake from konsole.
The command gave nothing: no message, no window.
journalcl -f gives:
nov. 11 09:41:46 ASUSROG kernel: INFO: task drakx11:11283 blocked for more than 120 seconds.
nov. 11 09:41:46 ASUSROG kernel: Not tainted 4.13.10-desktop-2omv #1
nov. 11 09:41:46 ASUSROG kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
nov. 11 09:41:46 ASUSROG kernel: drakx11 D 0 11283 11197 0x00000084
nov. 11 09:41:46 ASUSROG kernel: Call Trace:
nov. 11 09:41:46 ASUSROG kernel: ? __schedule+0x1b1/0x6d0
nov. 11 09:41:46 ASUSROG kernel: ? schedule+0x36/0x80
nov. 11 09:41:46 ASUSROG kernel: ? rpm_resume+0x10d/0x7b0
nov. 11 09:41:46 ASUSROG kernel: ? wait_woken+0x80/0x80
nov. 11 09:41:46 ASUSROG kernel: ? __pm_runtime_resume+0x47/0x70
nov. 11 09:41:46 ASUSROG kernel: ? pci_config_pm_runtime_get+0x27/0x50
nov. 11 09:41:46 ASUSROG kernel: ? pci_read_config+0x8f/0x260
nov. 11 09:41:46 ASUSROG kernel: ? simple_attr_release+0x20/0x20
nov. 11 09:41:46 ASUSROG kernel: ? kernfs_fop_read+0x9b/0x180
nov. 11 09:41:46 ASUSROG kernel: ? vfs_read+0x8c/0x140
nov. 11 09:41:46 ASUSROG kernel: ? SyS_pread64+0x93/0xb0
nov. 11 09:41:46 ASUSROG kernel: ? do_syscall_64+0x57/0xc0
nov. 11 09:41:46 ASUSROG kernel: ? entry_SYSCALL64_slow_path+0x25/0x25
nov. 11 09:41:46 ASUSROG kernel: INFO: task drakx11:11371 blocked for more than 120 seconds.
I’m unable to kill the process drakx11
I get a similar message when I try to shutdown the computer. I will open a new thread for this issue.
mandian
4
I also see something similar but only on intel processor based machine.
Yes, this laptop has two graphics cards: one Intel integrated and one Nvidia that I never succeeded to make it run.
mandian
6
I think it is related to the processor rather then the graphic chip.
Colin
(Colin Close)
7
Ok I guess it’s working for most. It certainlyis for me. I’ll release it.
Colin
I tested it on a desktop with GT 710. It works. It is even more stable then the nouveau driver.
ben79
(Ben Bullard)
9
These packages are now in non-free-updates. Closing topic.
