Caddy package
Hello, I’m new to OM and I’m trying to setup my env.
Caddy is not in the repositories but I found
dnf copr enable @caddy/caddy
which is for Fedora, will it work on OM or is there another way to install it?
Thank you
If it is not available in our repos I suggest submitting a package request here: Issues · OpenMandrivaAssociation/distribution · GitHub
And then building from source until the distro package is created: GitHub - caddyserver/caddy: Fast and extensible multi-platform HTTP/1-2-3 web server with automatic HTTPS · GitHub
I do not understand this.
Copr is an easy-to-use automatic build system providing a package repository as its output.
NOTE: Copr is not yet officially supported by Fedora Infrastructure.
copr is a build system for Fedora, I have no idea why anyone thinks this has anything to do with OpenMandriva. It does not. OpenMandriva’s build system is ABF.
@LeeTalbert’s advice is spot on for basically anything not in OM repos.
@LeeTalbert Thank you, I will try to build it from source.
@ben79 It’s dnf, when I tried to search for a solution copr was the first thing that showed up, this is why I asked if it will work. For example maybe there is a setting or a package that I could install to make it work even if it was not recommended.
I also tried using AI, several, but the AI thinks OM is Fedora or openSUSE, was given solutions for both.
I’m sorry, I will be asking more stupid questions.
Here is another one, should I make other topics for my questions or ask them in here, most are related to different packages and ways to install packages.
@athov there is no problem asking stupid questions. If there were I would not know much… Or is it better to say “the stupid question is the one you did not ask”?
I understand that searching dnf usually brings up things related to Fedora, they created this after all. OM does use dnf but we do things differently than Fedora. It may be that using copr for some things might work, just as any 3rd party .rpm might work. Might being the key work there.
Actually I appreciate the fact that you did ask before doing. Usually when I get in trouble it is because I did not do that, or some other error I made.
Instead of completely building it from source, they provide ready binaries so I just downloaded the latest caddy_2.11.7_linux_amd64.tar.gz, put it in a other drive and linked it to /usr/bin, now it’s even better if I need to reinstall OM.
