Bumblebee via its command optirun
no longer works, not a single error message even with -v --debug option. Also primusrun does not work but returns something …
$ primusrun -c glxspheres64
Polygons in scene: 62464 (61 spheres * 1024 polys/spheres)
ERROR in line 619:
Could not open display
I’m using nvidia driver 390
Found that nvidia driver 390 has something new with GLVND:
and some changes in bumblebee.conf are needed,
but I was not able to make bumblebee back reading the topic above.
I also found,
which mention GLVND and libraries to work with GLVND:
- libGL.so -> libGL.so.1 -> libGL.so.1.0.0 (GLVND)
- libGLX.so -> libGLX.so.0 (GLVND)
- libOpenGL.so -> libOpenGL.so.0 (GLVND)
- libGLdispatch.so.0 (GLVND)
- libGLX_nvidia.so.0 -> libGLX_nvidia.so.$VERSION
- libGLX_indirect.so.0 -> libGLX_nvidia.so.$VERSION
- libnvidia-glcore.so.$VERSION
- (tls/)libnvidia-tls.so.$VERSION
some of these libraries are not found at OM LX 3.03.
Everything seems ok with bumblebee:
$ systemctl status bumblebeed
● bumblebeed.service - Bumblebee C Daemon
Loaded: loaded (/lib/systemd/system/bumblebeed.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2018-12-28 22:31:34 -02; 58min ago
Main PID: 3822 (bumblebeed)
Tasks: 2 (limit: 4915)
Memory: 28.2M
CGroup: /system.slice/bumblebeed.service
├─3822 /usr/sbin/bumblebeed --use-syslog
└─6037 [Xorg]
Memory: 28.2M
└─6037 [Xorg]
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.arning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
Any help, thanks a lot
