Post-edit: ISO download no longer available will post screen-shots soon.
We have a demonstration of concept of a minimal GUI ISO with the option to install different desktops and package groups. It is Frugalware software using Calamares Installer and something like this would (so I’m told) be possible for OpenMandriva to do as well. As a demonstration of the concept I think this is a pretty darn good example.
To install a basic-cli only system all you have to do is deselect all the desktop packages and run the installer and you’ll have a boot-able, working basic-cli only system installed for server use or whatever. So this type of ISO may work for that purpose as well.
Post-edit: And a great big thanks to crazy (aka: Gabriel Craciunescu) for this test ISO.
Note:This is demonstration ISO created to demonstrate the concept of a flexible installer only. Also this in not a netinstall ISO. You are installing from disk or USB stick. This may be very important to some people where internet is slow and/or unreliable.
Post-edit: Also this is not exactly a basic ISO as @rugyada proposed except that the design of the Live environment is kept to a very basic level. As far as installing is is very customize-able and sort of fills the need for:
Command line only system install
Basic very light weight GUI system
Choice of Plasma5 only or LXQt only or Lumina only desktop with additional packages as user wishes.
Or obviously install everything on the list.
all in one ISO. I like this concept.
First in Live environment we can see this is in general a leaner system concept than current Lx 3 ISO’s. But remember user is not installing the Live environment user is installing package groups she/he chooses to install so installed system can be anything from no X server no GUI CLI only system to GUI system with multiple desktops with everything but the kitchen sink.
Remember folks this is a demonstration of a concept not a specific proposal.
Now let’s look at what I think makes this ISO unique and desirable for OpenMandriva to emulate which is the ability of the user to choose what they wish to install. And remember you still can install stuff after installing your system. Also note that the choices here are based on what crazy has available with FrugalWare not what OpenMandriva would likely provide. Our package groups would no doubt be different. For instance we probably would not have Gnome in our list unless we did something like “Official supported desktops” and Unofficial Community supported desktops". As I understand it the Official supported desktops for Lx 4 will be KDE/PLasma5, LXQt, and Lumina. If we do an ISO like this it is likely the LIve environment will be Lumina or LXQt. OK screen-shots:
So if you want a no GUI command line only system you just deselect all the package groups and install and you’ll have a bootable cli-only system. This is useful for folks wanting to set up servers with minimal overhead and other such uses. Or user can install one or more other desktops plus the choice to install or not install other package groups. So user wanting a lean system might install only Lumina desktop or LXQt and forego say “Multimedia packages” and/or “Office packages”. So I think people can see that this is useful to have one ISO that allows users many choices of the size and type of system they wish to install.
The ability to manually select packages when installing the system was a feature that I liked very much in old Mandriva. I miss this function very much and for this I think it is a very good idea.
@TPG thanks. I am sure that you are right, and I would be happy to do
But I’m not so skilled enough to know what are the basic packages needing for a minimal with GUI system.
Maybe you can mentor me?
Actually I would have already done some experiments if just I had a working omdv-build-iso tool in OM 3.x. I had been able to build locally some ISOs but never had lucky with “minimal/basic” as I’d wish.
Evidently I’ve been missing something…
Christina I am happy to give you instruction if you need it. Perhaps look me up on skype at some time.
I am running openbox in my current install…you can’t get much
more basic than that.
