Amarok crashes (Lx 4.1)
  • OpenMandriva Lx version:
    Lx 4.1
    KDE/Plasma
$ amarok
QtWebEngine::initialize() called with QCoreApplication object already created and should be call before. This is depreciated and may fail in the future.
Attribute Qt::AA_ShareOpenGLContexts must be set before QCoreApplication is created.
Got ERROR: "Can't open and lock privilege tables: Table 'mysql.servers' doesn't exist" errno: 2000
KCrash: crashing... crashRecursionCounter = 2
KCrash: Application Name = amarok path = /usr/bin pid = 12628
KCrash: Arguments: /usr/bin/amarok
KCrash: Attempting to start /usr/lib64/libexec/drkonqi from kdeinit
sock_file=/run/user/1001/kdeinit5__0
pa_write() failed while trying to wake up the mainloop: Bad file descriptor
Invalid write to eventfd: Bad file descriptor
Code should not be reached at ../src/pulsecore/fdsem.c:199, function void pa_fdsem_post(pa_fdsem *)(). Aborting.
Unable to start Dr. Konqi
Re-raising signal for core dump handling.
Aborted (core dumped)
Amarok appears dead upstream. There is some work towards getting this fixed, if it can be fixed. So this is IN_PROGRESS.
yes it got replaced by Elisa
